Buick 215cid Aluminum V8 Engine Block
Buick 215 Aluminum V8 Engine Block
orange arrow: i.d. number
green arrow: undrilled head-bolt boss
(Olds 215's have one extra bolt per cylinder)
GM 215 Aluminum V8 Engine Identification
(originally published in MG-V-8 Newsletter, Volume 2 Issue 1)
by Kurt Schley
The GM 215 cubic inch aluminum V8 engine (and its Rover descendants) have historically been the V8 of choice for MG conversions because of its light weight and compact dimensions. The engine was domestically available in a variety of 1961 to 1963 Buicks, Oldsmobiles, and Pontiacs and in several performance levels.
Stock horsepower ranged from the standard Buick Special's 155 H.P. / 210 lbs torque to the Oldsmobile Jetfire's turbocharged and fluid injected 215 H.P. / 300 lbs torque. Of course, the most desirable aluminum V8's are the higher performance versions with increased compression ratios and four barrel carburetors. [Editor's note: if you're going to rebuild a Buick 215 anyway, you can easily change compression ratio by selecting different pistons. To change compression ratio on an Olds 215, you're probably looking at swapping heads. That's another article. Buick and Olds 215's have entirely different valve covers, which is probably the quickest way to sort a stack of them. Heads and valve-train are what really make Buick and Oldsmobile 215's quite different, but that's another article too!]
Chart 1 illustrates the entire range of automobiles in which the aluminum V8 was available from GM and the stock performance ratings. The chart can be of great benefit when shopping through the newspaper auto ads or canvassing wrecking yards trying to locate an engine as the owners often have no idea which version is in the car. A slight complication is that GM offered an optional higher performance engine in several of their models. For instance, the Buick Special could be ordered with an optional 185 H.P. engine rather than the standard 155 H.P. However, the vast majority of the autos were produced with the standard engine as listed in the chart. Also note that, judged strictly by horsepower, the best 215 seems to be the Olds Jetfire at 215 H.P. / 300 lbs torque. This engine was the first domestic turbocharged powerplant available to the public. (See turbocharger article in this issue.) The Jetfire engines are still available but the intake system is unsuitable for MG conversions as the turbocharger is quite bulky and rebuild parts are generally costly and rare.
More often than not, when you do locate a 215 it will have been already removed from the car. Knowing the GM model from which the engine was originally installed can be helpful in determining history of the motor you are negotiating for. Chart 2 illustrates the engine I.D. system used by the three GM divisions for the aluminum 215.
Chart 1: GM Model and Standard Engine Configuration
  Year     Make     Model     H.P. @ RPM     Torque @ RPM     Compression     Carburetor
61 Buick Special 155 @ 4600 210 @ 3200 8.75:1 2Bbl
61 Buick Skylark 185 @ ???? ??? @ ???? 10.25:1 4Bbl
61 Oldsmobile F-85 155 @ 4600 210 @ 3200 8.75:1 2Bbl
61 Pontiac Tempest 155 @ 4600 210 @ 3200 8.75:1 2Bbl
62 Buick Special 155 @ 4600 210 @ 3200 9.00:1 2Bbl
62 Buick Skylark 190 @ 4800 ??? @ ???? 11:00:1 4Bbl
62 Oldsmobile F-85 155 @ 4800 210 @ 4800 8.75:1 2Bbl
62 Oldsmobile Cutlass 185 @ 4800 230 @ 4800 10:25:1 4Bbl
62 Oldsmobile Jetfire 215 @ 4800 230 @ 4800 10:25:1 1Bbl (turbo)
62 Pontiac Tempest 190 @ 4800 ??? @ ???? 11:00:1 4Bbl
63 Buick Special 155 @ 4600 ??? @ ???? 8:75:1 4Bbl
63 Buick Skylark 200 @ 5000 ??? @ ???? 11:00:1 4Bbl
63 Oldsmobile F-85 155 @ 4800 210 @ 4800 8:75:1 2Bbl
63 Oldsmobile Cutlass 185 @ 4800 230 @ 4800 10:25:1 4Bbl
63 Oldsmobile Jetfire 215 @ 4800 300 @ 3200 10:25:1 1Bbl (turbo)
Note 1: Rochester carburetors were used on all models.
Note 2: Either a three speed manual or a Hydro-Matic automatic transmission was included as standard-equipment in all model, but four speed manual transmissions were available as optional-equipment.
Chart 2: GM Engine Number and Number Location Chart
Buick Engine Numbers (stamped onto top surface of engine block, ahead of the passenger-side cylinder head)
Engine Number Format: A-B-C-DDDDDDD
Where:
      "A" was the model code (0="Special", 1="Special Deluxe", 2="Skylark")
      "B" was the model-year code (H="1961", I="1962", J="1963")
      "C" was a single-digit plant code
      "DDDDDDDD" was the production sequence number
Supplemental Engine Code Format: EE-FFF (stamped upside-down in the same location)
Where:
      "EE" designated performance specification
        (I="1962 / standard compression ratio /two barrel carburetor",
        HI="1962 / high compression ratio / four barrel carburetor",
        JM="1963 / low compression ratio / two barrel carburetor",
        JN="1963 / high compression ratio / four barrel carburetor")
      "FFF" is numerical (meaning unknown).
Oldsmobile Engine Numbers (stamped onto front of right-hand cylinder head)
Engine Number Format: AA-BBBBBBB
Where:
      "AA" designated rated power (S="155 H.P.", SG="185 H.P.", ST="215 H.P.", SH or SE="low compression export models")
      "BBBBBBB" was the production sequence number
Pontiac Engine Numbers (stamped on front of block on right cylinder bank
Engine Number Format: 21-AA-B-CCCCCCC
Where:
      "AA" was the model-year code (H="1961", I="1962", J="1963")
      "B" was a single-digit plant code
      "CCCCCCC" was the production sequence number
Photo by Curtis Jacobson, added with online publication.
Information about Buick's supplemental engine codes added in June 2014.
Copyright: text 1994, photo 2006. All rights reserved.
Use by written permission from "britishv8.org" only.
