Auto Test: MGB GT V8
MG Elegance, Rover Smoothness
Re-printed unedited by exclusive written permission of "Autocar".
This article originally appeared in their issue for the week ending August 16, 1973.
Effective combination of proven MGB GT and superb Rover 3500 V8. Good performance with
remarkable economy. Smooth fuss-free engine with good torque but little engine noise.
Perennial MGB faults. Too expensive.
Few cars have been more of an open secret than the MGB GT V8. From the moment that supplies
of the Rover V8 engine to Ken Costello were stopped, it was clear that British Leyland themselves
were intending to do a similar exercise.
There is a considerable market all over Europe and America for a smart Grand Touring car with
comfortable space for two people and their luggage, or for two and their small children or
their dogs, and such cars as the Reliant Scimitar GTE and the Lotus Elan +2 have sold well
as a result. It must also have worried British Leyland that they were not represented in
the "big" sports car range by the Austin Morris Division, following the termination of the
Austin Healey 3000, and the unfortunate public response to the MGC that led to its early
demise. As we said when the MGC was first tested, if there were no MGB by which to measure
it, the MGC would not have been considered such a bad car, and so it is heartening to see
that British Leyland are again prepared to capitalize on the excellent name of "MG" and to
try again.
The elegant Pininfarina-inspired lines are unaffected by the change in power unit, revised manifolding avoiding the
need for a re-shaping of the bonnet. The familiar MG insignia on the radiator has returned to its previous position at
the top centre of the grille surround, while the surround itself has returned to the shape and size that it was before
the 1971 revisions.
The combination of the timeless lines of the Pininfarina-influenced MGB GT and the smoothness
of the lightweight 3,528cc Rover V8 engine ought, on paper anyway, to make for an excellent
high performance sporting coupe. If the end product falls short in any way, it is in the
unfortunate perpetuation of the dated features of the MGB. Such shortcomings as excessive
wind noise, a harsh ride, and heavy steering may be forgiven in an out-and-out sports car,
but they have no place in a GT car costing over £2000. More unfortunate still is the
fact that such shortcomings are accentuated by the superb smoothness and relative quietness
of the excellent Rover V8 engine, which it must be admitted goes most of the way to making
up for the less likeable facets of the car.
In terms of performance, the Rover engine has moved the MGB GT V8 up into the realms of the
fastest European sports cars as it is capable of well over 120mph and its acceleration both
through and in the gears is excellent. Acceleration from rest to 90mph in under 20 seconds,
and a standing quarter mile time of 16.4 seconds are both very good, and the effortless way
in which the quiet V8 accelerates from as low as 10mph in top gear is impressive. In direct
top-gear, each 20mph increment from 10 to 80mph takes less than 8 seconds, while it takes
only 10.3 seconds to get from 80 to 100mph.
To provide this sort of performance, while paying attention to European Emission Regulations,
British Leyland use a version of the V8 engine that has most in common with the Range Rover,
utilizing the same low-compression pistons in both engines. To allow for a sufficiently low
carburetor height, the manifold is changed from the penthouse design of the Rover 3500 and
Range Rover, and a cast manifold is used, whose inlet tracts point towards the back of the
engine enabling the carburetors to be positioned close to the bulkhead, where there is more
available space.
There is little to show that the Rover V8 engine is not the original power unit of the
MGB GT V8, as the installation is
neat and well planned. The electrical service items such as fuses and relays are all
positioned on the offside of the
bay, while the radiator header tank and screen washer reservoir are on the nearside. The reservoirs for clutch and
brake hydraulic circuits are positioned high up behind the pedal box, but their proximity to the angle of bulkhead
and bonnet makes it difficult to see the fluid level. (Photo by Ken Smith. Used by permission.)
The gearbox derives from the MGC all-synchromesh unit that was introduced on all MGBs in 1967.
As used on the MGB GT V8, only the casing is changed to allow the use of a 9.5 inch diameter
clutch, while the internal ratios are higher than those of the 4 cylinder car to suit the
increased power and torque of the much larger engine. The ratios are well chosen, allowing up
to 40mph in 1st gear, and 100mph in third gear. Although 2nd gear gives up to 60mph, it is
spaced a little too close to 1st gear and would benefit from being a little higher.
Overdrive operates on top gear only and is geared up to give 28.5mph/1000rpm. While this may
seem to indicate a strictly "overdrive" gearing, it is surprising how often it can be engaged,
even around town, so torquey is the V8 engine. Engagement of the overdrive is by the lefthand
of two fingertip stalks, and while the unit disengages sweetly enough when the lever is pushed
away from the wheel rim, engagement is lazy and unduly speed-conscious, taking longer to
engage at low speeds than high, as the inhibitors sort themselves out, and decide whether or
not overdrive can be engaged.
One of the nicest features of the car is the complete absence of any snatch, vibration, or
harshness from the drive-line. From full throttle to overrun, there is little sign of the
considerable torque reversals that are taking place, and this contributes greatly to the
pleasure of driving the car. As this feature is present to a lesser degree in the Rover
3500S it is probably due in part to the V8 engine, but the very short propshaft must help
considerably in this.
There are absolutely no dramas involved in starting the car, either cold or hot. Under
cold-start conditions, the manual mixture enrichment needs to be used sparingly, and can
be pushed home within the first mile. In fact, the car runs smoothly without the need for
enrichment long before the heater starts to give much appreciated warmth.
Despite a good angle of attack, the clutch effort is inordinately high, and operating it
becomes a tiring exercise in town. Perhaps this is more noticeable as the full movement must
be used to avoid any grating on engaging the gears. It is essential to use the full movement
of the clutch when engaging reverse, as the gears continue to spin for a long time, and it is
often quicker to stop them by engaging first gear. The gearchange is also appreciably heavier
if the full travel of the clutch is not utilized.
The brakes are excellent, progressive and capable of producing a 1g stop at only 65lb pedal
load; the accelerated fade tests revealed only a slight tendency for the pedal load to
increase as the brakes became hot, and only on the 10th application from 70mph did they begin
to show any loss of performance, and that only slight.
All the MGBs are commendably tractable, and very easy cars to drive. They can all be pottered
gently without the need for critical use of gearchange points, and the V8 version distinguishes
itself by being even more free of fuss than its smaller-engined brothers. Never before has a
sports car in this class been as flexible and forgiving and so easy to drive smoothly, but
then again never before has such a smooth engine been offered beneath an MG bonnet.
What is remarkable is that this marked increase in performance and flexibility is accomplished
at little cost in fuel economy. Compared with the last MGB GT that we tested two years ago,
the V8 gave 23.4 mpg overall, compared with 23.7mpg overall for the smaller-engined car. While
it would be possible to get a slightly better "touring" performance from the four cylinder car,
this is partially offset by the fact that the Rover V8 engine can run on three star fuel, while
the four cylinder engine requires five star, and we would expect that the same driver on the
same journeys would get very similar figures in the two cars. When the considerable difference
in performance is taken into account, this is a quite outstanding achievement.
Ride and Handling
To cope with the 75 per cent increase in torque that the V8 has brought, the spring rates have been increased at the rear. There is a small balancing increase at the front that goes unnoticed, but the harder rear springs have turned the ride from hard to harsh, compared to the earlier MGB. This excessive rear end roll stiffness contributes to power oversteer that is in conflict with the natural understeering characteristics of the car. This is not a problem on long sweeping fast bends, but at lower speeds hard acceleration can produce a disconcerting imbalance as the transition from understeer to oversteer takes place. Further evidence of the imbalanced nature of car appears when one is forced to lift-off in the middle of a corner that has been entered at too high a speed to allow power oversteer to be induced. If the lift-off is sudden, the car tightens its line quite abruptly, necessitating rapid steering correction. Considering how very predictable the normal MGB is, and how predictable the Costello MGB V8 is, it would seem that the work on the rear suspension has not produced the desired results. It must not be assumed that the foregoing ascribes a serious degree of raggedness to the handling but since the MGB GT V8 must put down half as much power again as the four cylinder car and at the higher potential cornering speeds that the excellent Goodyear G800 tyres allow, it would inspire more confidence if the handling was more progressive. Extremely strong castor action contributes considerably to excellent straight line stability. It also makes for good resistance to side winds, but means fairly heavy steering effort.
Interior comfort and fittings
Many young families would consider the MGB GT V8 an ideal car for parents and children up to
seven or eight. With the children on the back seat, there is still sufficient room behind for
a great deal of luggage, and if the children are to be left at home, the rear seat can be folded
forward, further increasing the available load space, and leaving room for such bulky items as
school trunks or pram bases. Access to the luggage space is gained through the large rear door
that swings well out of the way, and is retained in the open position by two sturdy self
supporting struts. The spare wheel is housed below the floor of the load space, and is properly
secured by a large wing nut. The area around the spare wheel can be used to stow tools and oddments
that would otherwise be on display in the luggage area.
In the remainder of the car, stowage space is limited to a small glove locker (which, as we have
said many times, is infuriating as it can only be opened and closed by the key, which is
inevitably on the key ring, where it belongs.) and to a lift-up glove locker between the seats
whose aptly described by its title. There is also a useful map pocket on the passenger's side,
but this is out of reach, especially when static seat belts are being worn.
The rear seats are really only suitable for children up to about eight, although no doubt
older children would put up with
discomfort for the thrill of being driven in the car. The rear seat cushions are retained by "lift the dot" fasteners, and when
released allow the rear seat back to swing down onto the rear seat. - A surprising amount of luggage can be fitted into
the load area, and the two wells behind the rear wheel arches are particularly useful for stowage. A pram base will not
quite fit crossways between the wheel arches, and will not fit longways if the rear seat is in the raised position.
All the seats now have nylon facings on their wearing surfaces, and both the front seats can
be reclined. Adjustment of the front seats is generous and drivers of all sizes can be accommodated.
The backs of the front seats do, however, lack lumbar support and leave a space below the small
of the back that can lead to some discomfort. The seat backs are high and well-shaped, providing
good shoulder support, and the gripping nature of the brushed nylon material helps to provide good
lateral support. The backs of the seat recline, but only to approximately 45 degrees at which
angle they come up against the rear seats.
For the driver, the seating position relative to the controls is good, the gear lever falling
comfortably to hand, and the relationship of shoulder position to the small leather-covered
steering wheel enables a near straight arm posture to be enjoyed. Shorter drivers do, however,
tend to sit quite low in the car, making visibility of the front corners difficult.
The roomy interior of the MGB GT remains substantially unaltered, only the size of the instruments and calibration of
the speedometer to 140mph indicate the presence of the V8 engine beneath the bonnet. Unfortunately, the opportunity
has not been taken to level up the pedals and therefore it is still not possible to heel-and-toe.
The remainder of the interior appointments are in line with the normal MGB GT, with the exception of the speedometer and rev counter, which are the same small size as the American market cars. This is dictated by the larger shroud made necessary by the additional finger tip switch for the overdrive.
Living with the MGB GT V8
Static seat belts at £15.85 including VAT were the only optional extra on our MGB GT V8,
and so the price of £2293.96 had only the normal items of vehicle license/delivery charge
(including VAT) of £18.70 and number plates of £5.00 to give an on-the-road price of
£2352.43. The MGB GT V8 package includes all the items that are available as options on the
normal MGB GT. Included among these heated rear window, tinted windows, servo brakes, head
restraints, and of course the overdrive unit.
There should be few problems involved in getting nationwide service for the car, as Laycare now
extends to all British Leyland dealers, and this ensures fixed charges for routine servicing
anywhere in the country, and also ensures that there are technicians capable of servicing the
Rover V8 engine at all MG dealers. The cost of replacement parts is expected to be similar to
those for existing MG parts, while prices for the Rover engine should not be excessive.
Routine servicing is recommended every 6,000 miles, while a "safety check" service is recommended
every 3,000 miles if the car is used under dusty or arduous conditions. Access to items requiring
routine maintenance is good beneath the big aluminium bonnet, and a typically thoughtful feature
is a plastic grip on the dipstick, which remains cool. The engine has a no-loss cooling system,
and it is essential to check this while the engine is cool.
The electrical circuits are protected by four fuses in a fusebox, while there are two additional
inline fuses to protect the heater fan motor and the hazard warning flasher unit.
The spare wheel lives below the floor of the rear luggage compartment from which all luggage
must be removed in the event of a puncture. However, as the spare is inside the car, it stays
clean and dry, although it must be released from its stowed position and turned over for its
pressure to be checked.
The rear compartment of the test car became saturated with water during the course of the test
period. At first, poor sealing around the tailgate was suspected, but as the water only gets in
when the car is on the move, we would suspect that the grommet around the petrol filler cap was
not a good fit. This problem has been noticed with previous MGBs, and attention to this seal at
the early stages is advised.
There are no tools supplied with the car apart from a jack and wheelbrace which are stowed in a
substantial soft bag in the space occupied by the spare wheel. There is one jacking point on each
side of the car, and the jack has a good crank action, raising the car quickly.
Conclusions
To put the MGB GT V8 into perspective in the new market that British Leyland are entering, it
must be compared with a number of cars that have already carved a niche for themselves. For
instance, there is the Reliant Scimitar GTE at £2,439 or £2480 with overdrive, the
Datsun 240Z at £2535, the Lotus Elan +2 S130 at £2789 and of course the Triumph Stag
at £2533, while the Ford Capri 3000 GXL compares favorably at only £1824.
To hope to sell well against this powerful competition, the MGB GT V8 has to rely heavily on its
excellent smooth power unit, for in most respects of appointment and comfort it does not score
over the opposition. In terms of handling the MGB GT V8 scores over all but the Datsun and the
Lotus Elan +2, while in terms of ride, it must be rated at the back of the field. In view of the
fact that the development costs cannot have been high, it is difficult to understand how a
£500 differential can be justified between the MGB GT V8 and an MGB GT with the four
cylinder engine, and the same optional equipment. Undoubtedly the car will sell well on the MG
name alone, but it is a fiercely competitive area that the MGB GT V8 has stepped into, and if
it succeeds, it will be mainly due to the excellent Rover V8 engine for which praise cannot be
too high.
BritishV8 Magazine has assembled the largest, most authoritative collection of MG "MGB GT V8" information you'll find anywhere. Check it out! Access our MGB GT V8 article index by clicking here.
