MGB GT V8  -  PARTS SUPPLEMENT
Republished by special permission from Moss Motors, Ltd.
INDEX
   PAGE
BASIC INFO   LOCATION OF UNIT NUMBERS
SECTION A   POWER UNIT AND ANCILLARIES
  1 - 4 V8 Engine
  5 - 6 Carburetters Inlet and Exhaust Manifolds
  7 - 8 Engine and Gearbox Mountings, Engine Controls
SECTION B 9 - 10 OIL COOLER AND PIPES
SECTION C 9 - 10 CLUTCH COMPONENTS
SECTION D 11 - 14 GEARBOX
SECTION E 15 - 16 COOLING
SECTION F 17 - 18 EXHAUST SYSTEMS AND COMPONENTS
SECTION G 17 - 18 REAR AXLE AND PROPSHAFT ASSEMBLY
SECTION H   STEERING AND SUSPENSION
  19 - 22 Steering and Front Suspension
  23 - 24 Rear Suspension
SECTION I   HYDRAULIC SYSTEMS
  25 - 26 Brake, Clutch Master and Slave Cylinders
  27 - 28 Front and Rear Brakes
SECTION J   ELECTRICAL
  29 - 30 Ignition Systems, Starter Motors and Alternators
  31 - 32 Switches and Wiring Harness
SECTION K 31 - 32 SPEEDOS, REV COUNTERS, & WASHER BOTTLE
SECTION L 33 - 34 GRILLES, BADGES, & DOOR MIRRORS
SECTION M 33 - 34 JACKS, TOOLS, & WHEEL CAPS
Moss Motors provides both performance and original parts for MG and other British sports cars
Location of Unit Numbers
MGB GT V8 parts - POWER UNIT AND ANCILLARIES (V8 Engine)
SECTION A - POWER UNIT AND ANCILLARIES (V8 Engine)
NO.PART NO.DESCRIPTIONQTY/CARREMARKS
1 48G7631 E Exchange engine 1 9.26-1 C/R
1 48G7632 E Exchange engine 1 10.25-1 C/R
Exchange engines come without rocker box covers, water pump,
pulleys, oil pump base, dipstick, manifolds and flywheel.
2 625038 Filler cap 1
3 564258 O-ring 1
4 78862 Retaining screw 3
5 603672 HT lead retainer 2
6 610402 Retainer RH only 1
7 BHH 1208 RH rocker cover 1
7 BHH 1209 LH rocker cover 1
8 GEG 436 Rocker box gasket 2
603127 Rocker box screw long
602530 Rocker box screw short
9 532319 Dip stick seal 1
10 ERC 4558 Dipstick 1
11 602097 Rocker shaft bolt 8
12 606661 Rocker shaft 2
13 602148 Wavey washer 4
14 602186 Flat washer 4
15 603734 Pedestal 8
16 602153 RH angled rocker 8
16 602154 LH angled rocker 8
17 602142 Spacer spring
18 GSP 531 Sparkplug 8
19 614642 Cylinder head 2
20 GEG 340 Cylinder head gasket 2
21 603554 Valve guide 16
22 602166 Inlet valve 8
22 602165 Exhaust valve 8
23 602240 Outer spring 16
24 602241 Inner spring 16
25 602451 Top cap 16
26 602303 Valve cotter 32
27 603378 Push rod 16
28 614529 Cam follower 16
29 602191 Cylinder head bolt 8
29 602192 Cylinder head bolt 14
29 602193 Cylinder head bolt 6
30 602098 Cylinder head washer 28
31 602227 Bolt 1
32 602610 Washer 1
33 602159 Distributor gear 1
34 602149 Spacer 1
35 610289 Cam gear 1
36 ERC 7929 Timing chain 1
37 ERC 2003 Cam shaft 1
38 90602025 Woodruff key 1
39 8G 2707 Piston ring set 1Please state size.
40 606962 Piston 8Please state size.
41 8G 2705 Main end set 1Please state size.
42 8G 2704 Big end set 1Please state size.
43 612368 Flywheel assembly 1
44 611323 Flywheel ring gear 1
45 SH 607081 Flywheel bolt 6
46 602915 Drain tap LH 1
47 602082 Con rod 8
48 602609 Con rod bolt 16
49 602061 Con rod nut 16
50 602046 Oil thrower 1
51 90602372 Crank gear 1
52 90602025 Woodruff key 1
53 549911 Spigot bearing 1
54 611409 Rear oil seal 1
55 612989 Crankshaft 1
56 SH 610111 Crankshaft bolt 1
57 602411 Washer 1
58 603301 Ring 1
59 612421 Pulley 1
60 611089 Packing piece 2
61 603775 Gasket 1
62 602180 Gasket 1
63 610391 Front cover 1
64 602178 Packing oil seal 1
65 602158 Ring 1
66 602130 Main end bolt 10
67 BHH 998 Oil pump base 1
68 90602072 Gasket 1
69 90602064 Relief valve 1
70 BHH 1348 Relief valvespring 1
71 603521 Seal 1
72 602071 Plug 1
73 602017 Oil pump idler 1
74 602018 Oil pump drive 1
75 90602068 Gasket 1
76 602070 Strainer 1
77 GEG 539 Sump gasket 1
78 603434 Sump 1
79 213961 Drain plug seal 1
80 554164 Drain plug 1
81 SH 505051 Sump bolt 14
GEG 1155 Decoke gasket set 1
GEG 269 Conversion gasket set 1Use with decoke set.
V 8001 Locktite AVV 110cc size
V 8002 Locktite CVX 110cc size
V 8003 Wellseal 13.75oz size
GGC 102 Hylomar 14oz size
V 8004 Special bolt sealant 1To stop corrosion between
steel/aluminium joints.
V 8005 Plastigauge 1
V 8006 Coolant inhibitor 118oz size
GAT 140 Spark plug spanner 1
MGB GT V8 parts - Carburetters, Inlet and Exhaust Manifolds
SECTION A - POWER UNIT... (Carburetters, Inlet and Exhaust Manifolds)
1 242318 Carburetter gasket 4
2 610849 Spacer block 2
3 252514 Stud 8
NH 605041 Nut 8
4 BHH 1237 Hose, flame trap/cover 2
5 603330 Flame trap 2
6 BHH 1238 Hose, trap to carburetter 2
7 BHH 1005 Outlet elbow 1
8 GTG 125 Gasket 1
9 GTS 104 Thermostat 1
10 AED 172 Temperature sender unit washer 1
11 11K 2846 Sender unit adaptor 1
12 BHH 1064 Steam pipe 1
13 BHA 5252 Fan otter switch 1
14 257064 Locating screw 3
15 236022 Gasket 1
16 603441 Adaptor gasket 1
17 GEG 693 Manifold gasket 1
18 GEG 645 End seal 2
19 602076 Seal clamp 2
20 ERC 2278 By pass hose 1"S" shaped
20 ERC 2279 Heater return hose 190 degree shaped
21 90611532 By-pass pipe 1
22 13H 9216 Non return valve 1
23 232043 Washer 1
24 BHH 1001 Exhaust gasket 8
25 BHH 999 RH manifold 1
25 BHH 1000 LH manifold 1
26 CHS 2513 Stud 6
27 GHF 261 Brass nut 6Alternative.
27 AHH 8382 Helicoil nut 6Original fitting.
28 GEX 7193 Sealing ring 2
29 SH 506091 Manifold bolt 16
30 612435 Carburettor gasket 2
31 BHH 1162 Sleeve 2
32 BHH 1163 Air temperature control 2
33 GEE 1054 Air filter 2
34 BHH 1255 Air pipe 2
35 BHH 1297 RH top shroud 1
35 BHH 1298 LH top shroud 1
36 BHH 1247 RH lower shroud 1
36 BHH 1248 LH lower shroud 1
37 BHH 1213 U tube breather 1
38 603185 Clip 1
39 603183 Breather filter 1
40 BHH 1172 Pipe crankcase to filter 1
41 CUD 9266E Exchange carburetters 1 pair
42 CUD 2902 Damper 2
43 AUC 5156Screw 6
44 CUD 1142(BBU) Needle 2
45 AUD 4288Guide 2
46 AUD 4398Yellow spring 2
47 GSU 101Needle and seat 2
48 GSU 402RH Jet 1
48 GSU 403LH Jet 1
49 GSU 205Float RH 1
49 GSU 206Float LH 1
50 GSU 552Float seal 2
51 AUD 3590Float chamber screw 8
GSU 500Carburetter overhaul gasket kit 2
MGB GT V8 parts - Engine and Gearbox Mountings
SECTION A - POWER UNIT... (Engine and Gearbox Mountings)
1 BHH 991Engine mounting bracket RH 1
1 BHH 992Engine mounting bracket LH 1
2 BHH 1318Engine mounting rubber 2
BHH 1319Engine mounting packingA/RRH side only
3 AHH 7855Pin rear gearbox mounting 1
4 AHH 8431Top gearbox mounting bracket 1
5 AHH 8432Bottom mounting bracket 1
6 GEX 7453Gearbox mounting 2
7 AHH 7854Tie bar bush 2
8 AHH 8430Gearbox cross member 1
MGB GT V8 parts - Engine Controls
SECTION A - POWER UNIT... (Engine Controls)
1 BHH 1120Accelerator cable 1
2 BHH 1059Adjuster 1
3 AHC 284Trunnion 1
4 AHC 135Accelerator pedal 1
5 AHH 6504Distance tube 1
6 BHH 1121Choke cable 1Round knob
7 BHH 1121AChoke cable 1"T" handle
8 BHH 1056Trunnion block 1
9 BHH 1057Mounting bracket 1
MGB GT V8 parts - Oil Cooler and Pipes
SECTION B - Oil Cooler and Pipes
1 BHH 1104Pipe pump to filter 1
2 BHH 1341Pipe, filter to cooler 1Chrome bumper
2 BHH 1612Pipe, filter to cooler 1Rubber bumper
3 BHH 1103Pipe, cooler to pump 1Chrome bumper
3 BHH 1613Pipe, cooler to pump 1Rubber bumper
4 6K 431Washer sealing 4
5 AHH 6701Adaptor union 4
6 AHA 8401Pipe grommet 2
7 ARH 186Oil cooler 1Chrome bumper
7 ARH 185Oil cooler 1Rubber bumper
8 GFE 114Filter 1
9 BHA 5286Remote filter assembly 1
10 BHH 1231Oil gauge union 1
11 6K 464Washer 1
MGB GT V8 parts - Clutch Components
SECTION C - Clutch Components
GCP 208Clutch plate 1
GCC 180Clutch cover 1
GRB 224Release bearing 1
22B 725Release bearing clip 2
11G 3196Pivot bolt 1
11G 3195Pivot bush 1
22B 450Gaiter 1
12H 2178Washer 1
MGB GT V8 parts - Gearbox
SECTION D - Gearbox
1 90514854Inhibitor / reverse switch 2
2 1B 3664Spacer washerA/R
3 21H 6060Breather 1
4 BHH 2072Gaiter 1
5 BHH 788Gear level knob 1
6 54K1723Locknut 1
7 DAM 3079Lever 1
8 22B 525Bolt 3
9 2K 2545Washer 3
10 DAM 2576Plate 1
11 22H 15Bush 2
12 228372Gasket 1
13 228405Gasket 1
14 228295Bush 1
15 228 684Front cover 1
16 88G 545Oil seal 1
17 228385Gasket 1
18 22B 319Gasket 1
19 22B 356Nut 1
20 22H 798Lock tab 1
21 6K 778 Shim A/RSize 2 thou.
21 6K 779 Shim A/RSize 4 thou.
22 6K 780 Spring ring 1
23 6K 777Bearing 1
24 22B 7031st motion shaft 1
25 22H 7743rd motion shaft bearing1
26 22H 7723rd motion shaft nut 1
27 22H 773Lock tab 1
28 8G 30323rd motion shaft 1
29 228611Overdrivecam 1
30 37H 1911Circlip 1
31 22B 588Main bearing carrier 1
32 13H 7268Main bearing 1
33 22B 464Shim A/RSize 2 thou.
33 22B 465Shim A/RSize 5 thou.
33 22B 466Shim A/RSize 10 thou.
34 22B 425Distance Piece1
35 22B 516 Locktab 1
36 22B 515 Rearnut 1
37 NKC 39Overdrive oil seal1
38 22B 619 Overdrive rear flange 1
39 37H 3877 Rear overdrive nut 1
40 22H 1028 3rd and 4th baulk ring 2
41 22H 1168 3rd and 4th synchronizer 1
42 22H 1062 Sleeve 1
43 22B 562 3rd gear 1
44 22H 281 Gearbush 3
45 22H 1034 Interlock 1
46 22B 560 2nd gear 1
47 22H 276 2nd gear thrust 1
48 88G 397 lst/2nd baulk ring 3
49 DAM 4104 1st/2nd synchronizer 1
50 22H 827 Synchronizer spring 6
51 BLS 109 Ball 6
52 DAM 597 1st gear 11 tooth difference to original
53 DAM 1740 Reverse gear 1
DAM 2147Spacingwasher 1
54 22H 308Reverse gear idler 1
55 22H 310Bush 1
56 88G 467Reverse shaft 1
57 1B 3363Lock tab 1
58 1G 3581Locating nut 1
59 22B 691Front thrust washer 10.124"
60 22H 477Circlip 2
61 22B 702Lay gear 1
62 22B 280Lay shaft 1
63 22H 478Spacer tube 1
64 AHU 1041Lay gear bearing 2
65 22B 692Thrust rear 10.134"
65 22B 693Thrust rear 10.131"
65 22B 694Thrust rear 10.127"
65 22B 695Thrust rear 10.124"
65 22B 696Thrust rear 10.120"
66 22B 687Overdrive - new 1
66 22B 687EOverdrive - exchange 1
67 37H 1943Magnet set 1
68 37H 1942Filter assembly 1
69 37H 1946Screw 6
70 37H 1934Solenoid valve kit 1
71 NKC 102O-ring 1
72 NKC 99O-ring 1
73 37H 1935Coil only 1
74 BLS 106Ball valve 1
75 37H 1939O-ring 1
76 37H 1941Gasket 1
77 53K 126Screw 4
78 37H 3463Speedo drive 1
79 NKC 101O-ring 1
80 37H 1955Speedo bearing 1
81 NKC 105Oil seal 1
82 37H 1957Lock plate 1
83 37H 1959Screw 1
84 120694Angle drive 1
SGB 0008Gasket set 1
MGB GT V8 parts - Cooling
SECTION E - Cooling
1 ARA 2634Plug - plastic 1Alternative
1 ARA 2404Plug - brass 1Alternative
2 TRS 1418O-ring 1Alternative
2 TRS 1418APlasticseal 1
3 GRH 1002/MHose - radiator/expansion tank 1/3 metre
3 GRH 1001/MHose overflow 1/2 metre
4 21K8341Clip for above 2
5 ARH 250Expansion tank 1
6 BHH 2132Mounting bracket 1
7 GRC 110Tank pressure cap 1
8 ARC 88Radiator1Chrome bumper
8 ARC 88/ERadiator - reconditioned 1Chrome bumper
8 NRP 1059Radiator 1Rubber bumper
8 NRP 1059/ERadiator - reconditioned 1Rubber bumper
9 GRH 512Top hose 1
10 GHC 1622Jubilee clip 2Alternatives
10 GHC 1622/AWire clip 2Alternatives
11 GRH 511Bottom hose 1
12 GHC 1217Jubilee clip 2Alternatives
12 GHC 1217/AWire clip 2Alternatives
13 BHH 1304LH bracket 1
13 BHH 1052RH bracket 1
14 GWP 310Water pump 1
15 610756Gasket 1
16 ERC 2279Hose 90/elbow 1
17 ERC 2278S shaped hose 1
18 602582Pump pulley 1
19 GFB 11125Fan belt 1
20 BHH 1005Thermostat housing 1
21 GTS 104Thermostat 1
22 GTG 125Thermostat gasket 1
23 BHH 1064Steam hose 1
24 BHH 1082Hose - heater 1
25 BHH 1083Hose - heater to outlet pipe 1
26 BHA 5297Heater tap 1
27 12H 3868Heater - tap gasket 1
28 BHA 5407Heater-control cable 1
28 BHH 1230Air control cable 1
29 BHA 5226Heater control 1
29 BHA 4327Air control 1Chrome bumper
30 BHA 4334Heater knob 1Chrome bumper
30 BHH 738Air knob 1Rubber bumper
30 BHH 1687Heater knob 1Rubber bumper
30 BHH 1688Air knob 1
31 BHH 1305Fan guard 1
32 BHH 1028RH motor bracket 1
33 BHH 1306LH motor bracket 1
34 BHH 1029Mounting bracket 2
35 ALU 1081Fan - motor 2
36 13H 8238Fan 2
37 37H 8572Fan - locating screw 2
38 UKC 5146Relay 1
MGB GT V8 parts - Exhaust System and Components
SECTION F - Exhaust System and Components
1 GEX 7204Centre mounting 1
2 BH 605221Bolt 1
3 GEX 7182Bush 2
4 GEX 7183Bracket 1
5 GEX 7201Rear mounting bracket 1Chrome bumper
5 GEX 7442Rear mounting bracket 1Rubber bumper
6 GEX 7202Bracket 1
7 GEX 7203Clip 2
8 GEX 7251Mounting 2
9 AHC 442Insulator 4
10 GEX 7193O-ring gasket 2
11 GEX 138Exhaust system 1Chrome bumper
11 GEX 158Exhaust system 1Rubber bumper
MGB GT V8 parts - Rear Axle and Propshaft Assembly
SECTION G - Rear Axle and Propshaft Assembly
1 BTB 674Gasket 1
2 DAM 2441Back plate 1
3 6K 499Filler/drain plug 2
4 21H 6060Breather 1
5 BTA 249Nut 2
6 BTA 243Collar 2
7 BTB 187Stud 8
8 DAM 4122Drive flange 2
9 AAA 982Collar taper 2
10 GHS 179Oil seal 2
11 BTB 682Hub bearing cap 2
12 GHB 158Bearing 2
13 BTB 681Spacer 2
14 BTB 700Half shaft 2
15 BTB 900CW&P 13.071:1
16 BTB 432Bolt 8
17 BTC 9001Bearing differential 2
18 BTB 871Pinion pin 1
19 BTB 1249Differential pinion 2
20 1G 7445Thrust 2
21 BTB 428Gear wheel differential 2
22 ATB 7072Thrust 2
23 539706Inner bearing 1
24 BTB 853Collapsible spacer 1
25 549420Outer bearing 1
26 BTB 1326Oil seal 1
27 BTC 350Dust cover 1
28 BTB 855Prop flange 1
29 BTB 933Washer 1
30 BTB 753Nut 1
31 AHH 9268B Hubcap badge 4
32 BHH 1060Hubcap 4
33 BHH 1087Wheel nut 16
34 AHC 113Prop shaft 1
34 AHC 113/EReconditioned propshaft 1
35 22B 483Bolt gearbox end 4
35 53K 117Bolt axle end 4
GHF 223Nut 8
36 600656Range 2
37 GUJ 108Universal joint 2
38 27H 8095 Sleeve yoke 1
MGB GT V8 parts - Steering and Front Suspension
SECTION H - Steering and Front Suspension
1 BHH 868/FReconditioned steering rack 1Chrome bumper
1 BHH 1597/EReconditioned steering rack 1Rubber bumper
2 BHM 71241 pair gaiters and clips 1 set
3 GSJ 168Track rod end 2
4 17H 3501Gaiter 2
5 53K 320Nut 2
6 ADG 1682Clip-large 2
7 3H2963Clip-small 2
8 AHH 6007Shim A/R
9 18G 8905Steering lock 1
10 AHH 6000Universal joint 1Chrome bumper
10 575732Universal joint 1Rubber bumper
11 17H 3873Universal joint repair kit 1Chrome bumper only
12 AAU 1161Horn push 1
13 BHH 1307Steering wheel 1
14 BHH 2103Nut steering wheel 1
15 BHH 806Steering column 1Chrome bumper
15 BHH 1596Steering column 1Rubber bumper
16 BHA 5041Horn brush 1
17 BHA 5042Horn slip ring 1
18 BHH 803Cross member 1
19 AHH 6205Upper pad 4
20 AHH 6204Bolt mounting 2
20 BHH 805Bolt mountkig 2
21 AHH 6206Mounting pad - lower 4
22 AHH 6207Plate clamp 4
LNZ 108Nut 8
23 AHC 146Anti roll bar bolt 2
FNZ 108Nut 2Use with AHC 146
24 AHH 5939ARB brush 2
25 BHH 882Anti roll bar 1Chrome bumper
25 BHH 1217Anti roll bar 1Rubber bumper
26 AHH 6543RH link 1
26 AHH 6544LH link 1
27 21A 667Upper locator 2Chrome bumper
28 21A 668Lower locator 2Chrome bumper
29 AHH 6546Locator 4Rubber bumper
30 1B 7356Mounting strap 2
31 1B 4526Mounting bush 2Chrome bumper
31 AHH 6541Mounting bush 2Rubber bumper
32 GSA 119Front shock absorbers 2BL new unit
32 GSA 119AFront shock absorbers 2BL reconditioned
32 GSA 119EFront shock absorbers 2Standard reconditioned
33 1G 4349Top fulcrum pin 2
NL 607041Nut 2
34 8G 621Bush 4
35 AHH 6514Rebound buffer 2
36 AAA 5024Distance piece 2
37 BHH 1077Front spring 2
38 BTB 396RH steering arm 1
38 BTB 397LH steering arm 1
39 BTB 410Bolt 4
40 ATC 4249ATop castle nut 2
41 ATC 4249Trunnion block 2
42 BTB 764ERH exchange swivel and king pin 1
42 BTB 765ELH exchange swivel and king pin 1
42 BTB 764ARH exchange swivel and king pin 1Using BL king pin
42 BTB 765ALH exchange swivel and king pin 1Using BL king pin
43 BTB 183Spacer 2
44 GHS 101Oil seal 2
45 GHB 105Inner bearing 2
46 88G 484Spacer 2
47 ATB 42403 thou. shim A/R
47 ATB 42415 thou. shim A/R
47 ATB 424210 thou. shim A/R
47 BTB 65630 thou. shim A/R
48 BTB 187Stud 8
49 DAM 4121Hub 2
50 2A 4067Cap 2
51 GHB 102Bearing 2
GHK 1005Bearing kit 2Comprises 44,45 & 51
52 1A 4742Keyed washer 2
53 53K 330Nut 2
54 804221King pin set 2BL original
54 8G 4221AKing pin set 2Not BL
55 BTB 768Lower trunnion bush 2
56 1G 4271Dust tube top 2
57 2K 8951Dust tube spring 2
58 21B 251Dust tube bottom 2
59 NL 608041Castle nut 4
60 AAA 1330Washer 4
61 BHH 1123Bush 4
62 AHH 5927RH front wishbone 1
62 AHH 5929LH front wishbone arm 1
62 AAA 1326Rear wishbone arm 2
63 AHH 5925Spring pan 2
64 AHH 4003Inner pivot 2
65 ACB 5255Inner pivot bolt 8T grade bolts
66 LNZ 106Inner nut 4High tensile nut
66 FNZ 506Outer nut 4High tensile nut
67 ND 608041Castle nut 2
68 BHH 1773Distance tube 2
69 AAA 1323Seal 4
70 AAA 1390Thrust 4
71 AAA 1324Seal support 4
72 AHH 4001Special bolt 2T grade high tensile
MGB GT V8 parts - Rear Suspension
SECTION H - Rear Suspension
1 GSA 328RH shock absorber 1BL new chrome bumper
1 GSA 329LH shock absorber 1BL new chrome bumper
1 GSA 328ERH shock absorber 1Reconditioned chrome bumper
1 GSA 329ELH shock absorber 1Reconditioned chrome bumper
1 GSA 368RH shock absorber 1BL new rubber bumper
1 GSA 367LH shock absorber 1BL new rubber bumper
1 GSA 368ARH shock absorber 1BL reconditioned rubber bumper
1 GSA 367ALH shock absorber 1BL reconditioned rubber bumper
1 GSA 368ERH shock absorber 1Reconditioned rubber bumper
1 GSA 367ELH shock absorber 1Reconditioned rubber bumper
2 GHF 203Nut 4
3 GHF 334Spring washer 4
4 GHF 303Flat washer 4
5 BH 607261Bolt 4Chrome bumper
5 BH 607241Bolt 2Rubber bumper
5 BH 607261Bolt 2Rubber bumper
6 37H 8075Link 2Chrome bumper
6 37H 8778Link 2Rubber bumper
7 AHC 109U-bolt 4
8 GHF 223Nut 8
9 AHH 9158Bump stop 2
10 BHH 1030Pedestal 2Chrome bumper
10 AHH 7335Pedestal 2Rubber bumper
11 AHH 7334Plate locating 4
12 ACG 5002Spring seat - rubber 4
13 AHH 7337RH bottom plate 1
13 AHH 7338LH bottom plate 1
14 BHH 1133Spring assembly 2Chrome bumper
14 BHH 1771Spring assembly 2Rubber bumper
15 AHH 6446Front spring bush 2
16 GHF 203Nut 2
17 GHF 334Washer 2
18 BH 607241Bolt 2
19 AHH 5018Shackle 2
20 2A5176Bush 8
21 AHH 5019Shackle plate 2
22 GHF 333Washer 4
23 GHF 202Nut 4
24 BH 605151Check strap bolt 2
25 AHH 6162Distance tube 2
26 8HH 989Check strap 2
27 GHF 301Washer 2
28 GHF 331Spring washer 2
29 GHF 201Nut 2
30 GHF 202Nut 2
31 GHF 332Spring washer 2
31 GHF 302Flat washer 2
MGB GT V8 parts - Brake, Clutch Master and Slave Cylinders
SECTION I - Brake, Clutch Master and Slave Cylinders
1 8G8258Brake master cylinder repair kit 1Changed during production
1 BHM 7125Brake master cylinder repair kit 1Changed during production
2 SHA 5076Servo 1
AAU 2071Servo-hose to valve 1
3 GMC 15QBrake master cylinder 1
4 233220Gasket 3Servo & master cylinders
5 7H7851Banjo 2Servo & brake master cylinders
6 3H550Gasket 3Servo & master cylinders
7 C5192Banjo bolt 2Master cylinders
8 BHA 4310Banjo 1Clutch master cylinders
9 AHH 8556Cover 1
10 AHH 6156Seal 1
11 AHH 7052Seal 1Chrome bumper
11 BHH 1608Seal 1Rubber bumper
12 AHH 8522Brake pedal 1
12 AHH 6154Clutch pedal 1
13 AAA 4129Pivot bush 2
14 AAA 1628Return spring 2
15 AHH 5100Pedal rubber 2
16 CLZ 514Clevis pin 2
17 AHH 8421Master cylinder box 1
18 513123Filler cap 1
19 BHA 5217Clutch master cylinder 1
20 8G8730Repair kit - clutch master cylinder 1
21 37H 8090Clutch master cylinder push rod 1
21 17H 7985Brake master cylinder push rod 1
22 BHA 4675Brake switch
23 NT 606041Locknut 1
24 DAM 620Slave cylinder
25 BHM 7061Repair kit 1
26 3H2428Bleed nipple 1
27 13H 3655Push rod 1
28 2K 5622Clevis pin 1
29 ACC 5509Flexible hose 1
30 2K 8686Lock nut 1
31 90577490Connector 3-way 2
32 GBH 159Rear brake hose 1
33 BCA 4002Connector 1
34 TM 606031Connector male A/R
35 11D 5050Connector female A/R
36 GBH 158Front brake hose 2Fitted up to GD2DI 2707
36 GBH 172Front brake hose 2Fitted from GD2D1 2708
37 233220Seal 3
38 NT 606041Nut 3
39 1G 9198Locking plate 3
MGB GT V8 parts - Front and Rear Brakes
SECTION I - Front and Rear Brakes
1 37H 8100RH caliper 1
1 37H 8099LH caliper 1
2 BTC 114Lock tab 2
3 ATB 4074Locating bolt 4High tensile bolt
4 BTB 198Disc bolt 8High tensile bolt
FNZ 506Disc nut 8High tensile nut
5 BTB 1319Disc 2
6 BTB 1320RH back plate 1
6 BTB 1321LH back plate 1
7 GBP 2124 brake pads 1 set
8 PS610241Split pin 4
9 17H 7990Anti rattle spring 4
10 GBH 158Front brake hose 2All chrome and upto GD2D1 2707 rubber bumper
10 GBH 172Front brake hose 2From GD2D1 2707 rubber bumper
11 37H 8100 ACaliper piston 4
12 8G 8641Caliper seal kit 2Do not split caliper body
13 3H 2428Bleed nipple 2
14 BTB 706Brake drum 2
15 17H 7994RH pull off spring 1
15 17H 7995LH pull off spring 1
16 27H 6478Pull off spring - adjuster end 2
17 27H 6479Handbrake pull off spring 2
18 17H 7993Steady pin 4
19 17H 7969Steady spring 4
20 17H 7971Clip washer 4
21 17H 8057Hand brake lever boot 2
22 37H 2005RH hand brake lever 1
22 37H 2006LH hand brake lever 1
23 513107Adjuster assembly 2
27H 2203Wedge screw 2Part of 513107
27H 6472Tappet 4
24 GWC 1103Wheel cylinder 2
25 8G 8674Repair kit 2
26 17H 7949Retaining clip 2
27 513118Bleed nipple 2
28 GBS 772Brake shoe set 2
29 27H 6476RH back plate 1
29 27H 6477LH back plate 1
30 GBH 159Rear brake hose 1
31 SF604051Brake drum screw 4
32 AHH 8450Hand brake cable 1Chrome bumper
32 BHH 1470Hand brake cable 1Rubber bumper
GBF 101Brake fluid 1Small
GBF 102Brake fluid 1Medium
GBF 103Brake fluid 1Large
GAT 101Brake bleed valve kit 1
MGB GT V8 parts - Ignition Systems, Starter Motors and Alternators
SECTION J - Ignition Systems, Starter Motors and Alternators
1 GDC 117Distributor cap 1
2 608194Vacuum unit 1
3 GRA 112Rotor arm 1
4 GCS 117Points 1
5 GSC 111Condenser 1
6 614033Distributor 1
7 602397Clamp 1
8 513682O-ring 1
9 614768High tension coil to distributor 1
10 GHT 107Complete high tension lead set 1
11 GCL 111Coil 1
12 603673Spacer for high tension leads 2
13 37H 4229/MVacuum pipe 12/3 metre
14 12B 2095Straight pipe connector 1
15 12B 206290 degree pipe connector 1
16 BHA 5195Alternator 1
16 BHA 5195EAlternator - exchange 1
17 602369Fixing bracket 1
18 BHH 997Adjusting bracket 1
19 BHA 5223Starter 1
19 BHA 5223/EStarter - exchange 1
20 BAU 1091Solenoid 1
21 37H 8048Kit - drive roller clutch 1
22 GSB 111Starter brushes 1 set
23 BHH 1260Heat shield 1
90611504Starter mounting bolt 2
MGB GT V8 parts - Switches and Wiring Harness
SECTION J - Switches and Wiring Harness
1 18G 9012Indicator cowl 1
2 BHA 5113Heater switch 1
3 BHA 5296Rear window heater switch 1
4 BHA 5267Hazard warning switch 1
5 BHA 5111Light switch 1
6 37H 7994Panel light switch 1
7 37H 7995Knob for above 1
8 37H 8101Indicator switch 1
9 37H 8102Horn brush and bracket 1
10 BHH 402Indicator cancel mechanism 1
11 BHA 5251Wiper/washer/overdrive switch 1
12 13H 2018Tailgate light switch 1
13 BHA 4593Interior light switch 1
14 ZKC 1152Lighter 1
15 563417Starter relay 1All chrome bumper models
16 CHM 68Starter relay 1Rubber bumper, GD2D1 2742 on
17 37H 4727Fuse box 1
37H 4727 AFuse box cover 1
18 BHH 1223Main harness 1
18 BHH 385Body and boot harness 1Chrome bumper
18 BHH 1742Body and boot harness 1Rubber bumper
MGB GT V8 parts - Speedos, Rev Counters and Washer Bottle
SECTION K - Speedos, Rev Counters and Washer Bottle
  Note: Up to GD221 1148: oil pressure reading taken from filter housing.
4 BHH 1285Pipe (filter to flexible connector) 1
  Note: From GD2D1 1149: oil pressure reading taken from oil pump base.
1 AHA 6392Pipe (oil pump to flexible connector) 1
5 BHH 1347Flexi hose 1
3 88G 308Clips 2
4 BHH 1345Pipe (flexible-to-flexible) 1
  Note: All models require these parts at the oil pressure gauge end.
4 BHH 1281Pipe (gauge to flexible connector)1
2 CHA 600Flexible connector 1
3 880308Clip2
6 BHA 5331Dual guage 1
6 SDG 4004 EReconditioned dual gauge 1One for one only.
7 BHA 5212Tacho RVC/1810/00 1
7 MGP 1810 OOETacho-reconditioned 1One for one only.
8 BHA 5210Speedo SN 5230/uS 1
8 MGP 5230 11ESpeedo reconditioned 1One for one only.
9 GSD 115Speedo cable 1
11 GWW 125Washer pump 1
12 BHH 1154Bracket 1
13 GWW 901Bottle 1
14 GWW 952Cap 1
15 GWW 951Filler adaptor 1
MGB GT V8 parts - Grilles, Badges and Door Mirrors
SECTION L - Grilles, Badges and Door Mirrors
1 BHH 824Honeycombe grille assembly (original)1Chrome bumper models
1 BHH 831Grille surround (original)1Chrome bumper models
2 BHH 829Grillebadge-red 1Chrome bumper models
3 ARH 1800Plinth 1Chrome bumper models
4 BHH 1614Air grille duct 1Rubber bumper models
5 BHH 1753Mesh grille 1
6 CHA 344Red/silver nose badge 1GD2D1 2101 to 2722
6 CHA 544Black/silver nose badge 1GD2D1 2723 to 2903
7 BHH 1400RH GT rear quarter flash 1GD2D1 2723 to 2903
7 BHH 1401LH GT rear quarter flash 1GD2D1 2723 to 2903
8 BHH 855Tailgate badge - blue flash 1All models upto GD2D1 2722.
8 HZA 5024Tailgate badge - black flash 1GD2D1 2723 on
9 CZH 2717House badge 1Nearside wing only
10 HZA 4701V8 badge 3/2Qty reduced on rubber bumper
10 HZA 5022V8 badge - gold 2Last few cars only
8 HZA 5023Tailgate badge - gold 1Last few cars only
6 CHA 507Nose badge - gold 1
11 GAM 211Offside mirror - convex 1
11 GAM 212Nearside mirror - convex 1
11 GAM 213Offside mirror - flat 1
11 GAM 214Nearside mirror - flat 1
MGB GT V8 parts - Jacks, Tools and Wheel Caps
SECTION M - Jacks, Tools and Wheel Caps
1 BHA 5329Jack 1
2 AHH 6540Tool roll 1
3 BHH 1111Spare wheel clamp 1
4 BHH 1086Spanner
5 BHH 1087Wheel nut 16
6 BHH 1060Hubcap 4
AHH 9268BHub cap badge 4Use with BHH 1060.
BHH 1330RH Kangol seat belt Auto 1
BHH 1331LH Kangol seat belt Auto 1
BHH 938Seat belt park 2
This British Leyland publicity photo appeared on the back cover of the Moss parts catalog.
