There's Soupability in GM's Aluminum V8's
Re-printed unedited from "Speed Mechanics" magazine. This article originally appeared in August, 1961.
by Alex Walordy
Buick and Olds were the first, this year, to come through with all new aluminum engines of
advanced design. While the 215 cubic inch displacement and 3.50 by 2.80 bore and stroke are
common to both versions, there are some sharp differences in appearance, cylinder head and
manifold design that makes each engine stand out.
The most striking advantages from a user's point of view, are the remarkable low weight of
these powerplants, just 318 pounds, for an output of 150 horsepower at 4,400 rpm on the Olds
and 155 horsepower on the Buick. This is power obtained from a stock engine, fitted with a
single two-barrel carburetor, so that the possibilities are largely untapped. The present
two-pounds-per-horsepower ratio will no doubt move down to a pound-and-a-half per-horsepower,
or even less, as normal development takes place.
Design with aluminum is different than with cast iron, and offers several manufacturing possibilities.
Sand casting, with sand cores and patterns is one and follows the same methods as are now
used in pouring cast iron blocks. A number of castings can be made from a single permanent mold,
with the added advantage of superior finish and closer tolerances. Die casting makes use of
pressure-injected molten aluminum poured into special dies. While its initial steps are
comparitively costly, the long die life helps balance out costs.
Olds engine compartment can be spotted by round filter base cast into manifold and by inclined rocker covers.
Its aluminum block is a semi-permanent molding with cast-in iron sleeves. Reinforcing webbing shows good quality.
This section through manifold shows two quarters. Riser from carb is sectioned at top. All passages are in a
water jacket. Buick's conventional snorkle silencer does not have cast rib at manifold base.
Die casting, being an automatic process, requires a direct withdrawal of the dies as the casting
is completed. This has, so far, made it impractical to cast a block with a full cylinder deck.
Instead, the cylinders are left standing free, tied in only at the bottom of the block. This
poses sealing problems that will no doubt be solved shortly, but as yet this is not the most
desireable solution. A wet sleeve design, where the cylinder liners are removeable, makes
die casting very practical, but this method is too expensive for passenger car use, by Detroit
passenger car standards.
Buick and Oldsmobile hoped for a semi-permanent mold casting, with cast-in iron sleeves.
Semi-permanent means the use of a combination of permanent molds for the outside of the
block and the outside of the tappet valley, while sand cores are used for the water jackets
and the inner bulkheads. There are high-silicone aluminum alloys that would allow direct
use of pistons and rings against the aluminum. On the other hand, these alloys are expensive,
and more difficult to machine than the alloy selected for the 215 inch block.
To insure good cylinder life, centrifugally cast iron sleeves are used. It should be added that
this type of sleeve allows closer selection and control of desireable wear characteristics than
even a normal cast iron block, as the sleeves are relieved of the need for carrying great
structural loads.
An eight pitch thread cut .005 to .015 inches into the outsides of the cylinder liners retains
them in the block after the aluminum is poured. Even though aluminum expands more than cast
iron, the sleeves never become loose because they are closer to the heat source and because
there is an unavoidable heat barrier at the junction of the sleeves with the block.
The .093-inch thick cast iron sleeves have flat, wide threads turned on their outsides to provide good grip.
Buick rockers sit almost straight up, just as in the larger V8. The easily accessible distributor is at the front.
The crank is a conventional cast alloy iron unit, fully counter-balanced, with large journals and a 3/4-inch overlap between mains and rod journals. The main bearing diameter is set at 2.2986 inches and width is .802 inches except at the number three main which takes up end thrust and is .821 inches wide. A hefty rubber-mounted vibration damper testifies to the care used in making the first aluminum engine a smooth running one. Deep skirts on the sides of the block extend beyond the of the main bearing caps, contributing to rigidity and good crankshaft support. The main bearing caps are made of cast iron.
The short stroke presently used (2.80), can probably be extended to three or 3.25 inches to offer a displacement of 230 or 250 cubic inches. Incidentally, this is the only possibility of increasing displacement on this engine, as the dry liners in the block are only 0.93 inches thick and will not allow boring beyond .030 oversize, a meager gain at best.
All accessory parts (left) have considerable amounts of aluminum in them. Die cast timing case cover houses
parts of various components. Complete Buick engine weighes 318 pounds, develops 155 bhp at 4,400 rpm.
The diecast timing case cover accurately locates the rope-type oil seal at the front of the crankshaft.
A protrusion around the seal and an effective slinger keep most of the oil away from the seal,
reducing the amount of fluid they must control. In addition, a ridge cast into the inside of
the of the timing case cover acts as a roof over the seal, and further contributes to keeping
most of the oil away from it. The timing case cover also serves as the fuel pump mounting and
as the housing for the oil pump. While Oldsmobile uses an optional oil filter, Buick carries
the oil filter as standard equipment. When the filter is used, it replaces a large size plug
at the bottom of the housing.
The forged rods are quite short (5.660 inches center-to-center) and light (17.5 ounces).
Wristpins are pressed into the rod and float in the piston. This eliminates the need for
wristpin retainers in the piston or rod bushings. As in good aircraft practice, the wristpin
is very thick to avoid rod deflection under load.
The pistons are all aluminum, without expansion control inserts. The conventional slots are
placed between the skirt and the head of the piston at the bottom ring groove, forming a
heat dam and leaving the head tied to the skirt only in the areas above the wristpin bosses.
When the top of the piston warms up, it expands equally in all radial directions. At the
points where it is tied to the skirt, a hoop effect takes place with the skirt being pushed
outward at the wristpin bosses and, therefore, pulling in at the thrust faces.
The cam-ground piston is narrower across the wristpin bores than at the thrust faces. When
the piston expands in the bore, the thrust faces are pulled inward. Slap at the thrust faces
is controlled whether the piston is hot or cold. In customary strut designs, a steel strut
is put to work accelerating, or amplifying, the hoop motion. In Buick and Oldsmobile's
all-aluminum piston, the stiffness of the webs which tie the piston crown to the wristpin
bosses is balanced against the stiffness of the skirt, itself, to achieve the needed hoop
action.
Buick's cast iron exhaust headers (left) are remarkably well-thought-out as regards gas flow.
Dished (Buick) pistons combine with small combustion chamber.
The bottom of the piston skirt forms a full hoop. Buick feels that this is stronger than slipper piston designs of equivalent weight and helps control the action of the piston in the cylinder. Two large size slots separate the bottom of the piston skirt from wristpin bosses. This avoids skirt distortion and any restraining action which the skirt may have on the pin bosses. If you consider a wristpin as a beam which is supported in the middle and loaded at the ends, some deflection becomes inevitable. The best solution for retaining maximum bearing area at the pins is to let the bosses flex with the pin.
Fully machined combustion chambers and typical Buick design characterize excellent aluminum heads seen here.
Accessibility and ease of service are highlights of Buick engine compartment.
Buick and Olds differ drastically in combustion chamber design. Olds has a wedge type
chamber, flat top pistons, and a port configuration which largely resembles that of the
larger Olds engine. Buick has a machined chamber of comparatively small volume and
dished pistons. The valves on the Olds are angled to line up with the slant roof of the
combustion chamber. On the Buick, they are placed almost straight up, and the port design
is of course closely akin to that of the larger Buick engine. Even valve cover placements
are distinctively those of their larger engine counterparts.
Buick claims a more favorable surface to volume ratio at combustion time, together with
a central plug location and very short flame travel through the major portion of the
compressed air fuel mass. The squish area is distributed all around the piston and
combustion chamber, creating a favorable turbulence. These dished pistons are quite
reminiscent of those which enabled GM Research to run some very interesting tests at
compression ratios ranging from 10:1 all the way to 25:1, or six points higher than with
most diesels.
Small Rochester two-barrel (left) is housed in (Olds) air filter and silencer container. Cylinder head, too is
aluminum (below), has cast iron guides and steel seats. It also is cast by the semi-permanent method.
The use of a dished section makes compression changes quite simple, and we might add that
the use of a flat Olds piston in a Buick 215 would result in a compression ratio of 11:1.
Where a dish is very deep and falls below the ring belt, some distortion can occur at
operating temperatures and added heat is transferred to the piston. However, here the
dish is so shallow as to have no practical effect.
Engine cooling is quite elaborate. The aluminum water pump is bolted to the die cast timing
case cover which also serves as the back of the impeller housing. Each of the two headers
cast within the timing case cover leads directly to the corresponding cylinder bank. The coolant
flows through the banks and up to the rear of the heads. After reaching the front of the
heads, the coolant is then directed through the manifold to the radiator.
To insure quick and even warmup, the coolant must first course from front to rear along the
underside of the manifold risers, then reverse its flow and pass over the top of the risers
before returning to the radiator. The use of water as the source of manifold heat eliminates
an exhaust crossover, exhaust gas corrosion and a heat riser valve that traditionally rattles
and sticks.
Spark plug boss is water cooled, as are valve guides. Special press fit holds guides in place. Removal of manifold reveals
embossed sheet metal valve cover doubling as manifold gasket. Pad at top of cover prevents drumming, aids silencing.
Block water jackets extend the full length of ring travel, plus a good 1/4 inch. The spark
plug bosses are completely surrounded by coolant. Decks at the head and block are almost entirely
closed, except for an opening at the rear of the block. As the heads are interchangeable from
side to side, symmetrical openings are used front and rear. Thus, all of the coolant is directed
through the block and head.
The slanted portion of each cylinder bank being partially above the openings at the rear,
some venting is needed to avoid trapping air pockets during filling. Here again, we come to
a difference between Buick and Olds. Olds uses four quarter-inch "steam holes" to vent the
upper part of the block. "Steam hole" is actually a misnomer, for they are only vents. Buick
on the other hand, found the four holes unnecessary and uses only one small one at the front
of each bank.
Cover diverts oil poured into engine from rocker arms. Valley offers clear oil return without any stagnent pockets
usually found. Fully machined (Buick) combustion chamber, unpocketed valves, allow ample breathing.
Spark plug is in center. Squish area surrounds chamber.
Spark plug bosses (above) are angled to clear underneath exhaust ports. Aluminum water pump (left) is used
in conjunction with aluminum timing case cover. Ports discharge into block.
As you notice, the cooling systems use aluminum almost exclusively, except for the embossed
steel gaskets. Hence the possibility of galvanic corrosion is considerably reduced. We asked
specifically about special anti-freeze and were told by Buick that there were no plans or call
for any at the present. The use of aluminum, with its high thermal conductivity, in the large
cylinder block and head areas has enabled radiator size to be scaled down an appreciable
amount in comparison to the area needed for equivalent cast iron engines of the same power.
The blocks are fully leak tested when partially machined, and again when completed. If the
leakage exceeds specified rates, they are impregnated. Over that, they are scrapped. Impregnation
of both pressure and non-pressure types is used. Dry sealant pellets are added as a purely
precautionary measure.
The cylinder heads use copper-infiltrated, sintered iron inserts on both intake and exhaust
valve seats. Valve guides are cast iron, pressed into the heads. Although no drastic improvement
has resulted from use of aluminum as cylinder head material, there is a slight gain in mechanical
octanes and a reduction of, or elimination of, potential hot spots. A rocker arm shaft rather
than GM's favored ball socket arrangement is used. Part of the reason is that the pushrods are
offset. Also, it would be difficult to retain rocker studs in the head by press-fitting them,
and threads would be too expensive both in production and in assembly. Full gallery oil pressure
is supplied to the rocker shaft through passages in the block head and a rocker shaft bolt.
The openings for oil supply to the individual rockers are moved out of the load area to
increase flow.
The camshaft is cast iron, and has fairly mild timing. A sintered iron cam keyed on the
camshaft operates the fuel pump. Hydraulic lifters are used as standard equipment, and
the differences in expansion between steel and aluminum may well make them essential for
noise reasons. The tappet valley is covered by an embossed steel section that also serves
as the intake manifold gasket. By relieving the manifold of duty as a valley cover, much
webbing between the risers can be eliminated with resultant weight savings. A foil-covered
insulation bag laced between the manifold and the embossed cover eliminates noise and drumming.
Oldsmobile manifolds have cast-in bases for air filters, which increase the silencer volumes
and are claimed to reduce noise. Buick uses a snorkel-type air cleaner and eliminates some
of the manifold complexity. Our trained ear couldn't detect any appreciable difference between
the two.
The advent of the aluminum engine will not only herald a new era in engine weight reduction,
but also the building of many specials which, until now, had to be on the ponderous side.
A saving in weight cannot be estimated on the basis of weight difference with an equivalent
cast iron unit. There are also attendant weight savings in frame structure, drive train
size, etc. These new Buick and Olds engines will undoubtedly influence the future of the
automotive industry.
If you enjoyed this article, check out: Autocar Magazine's : History of the Buick / Rover Aluminum V8.
