Robert Milks' 1965 MGB with Buick 215 V8 Engine
(Originally featured in British V8 Newsletter, Volume 11 Issue 2. Updated July 2006 and December 2010.)
Owner: Robert Milks
BritishV8 UserID: RobM65BV8
City: Hendersonville, NC
Model: 1965 MGB
Engine: 1963 Buick 215 V8
Conversion performed by: Gary Nye of Nye Performance, Brevard NC
Engine: 1963 Buick 215ci aluminum V8. Bore/Stroke 3.5"/2.8" Cam is a Crower 50232 with an intake lift of 0.488", an exhaust lift of 0.490". Duration at 0.05": intake 214 degrees, exhaust 218 degrees. Lobe separation angle: 112 degrees. Cylinder heads are stock, with 1.5" intake and 1.312" exhaust valves. The compression ratio is 9.6:1. The engine is equipped with both lateral and rotational stabilizers. Valve covers are MGB. Engine mounts are Chevy.
Intake: 500CFM Edelbrock 1404 carburetor, jetted by D&D Fabrications, sits atop a stock manifold. Throttle linkage is also from D&D.
Engine Electrical: Pertronix ignition, MSD 6A control box and coil, Painless wiring. The alternator is an 80 amp unit, and the starter is a mini, both from D&D Fabrications. All engine bay wiring is hidden.
Cooling: A v-belt drives the stock aluminum water pump. (Note: An 18" x 18" 4-row brass downflow radiator by D&D Fabrications was originally used, but as of 2010 it's been replaced with an aluminum BeCool radiator.)
Exhaust: RV8 headers, Jet Hot coated by D&D, with a 1 3/8" primary tube ID. Muffler is glass-pack type, with an "Ansa" tip. Exhaust pipes are also 1 3/8" ID.
Transmission: Borg Warner T5 5-speed (rebuilt by D&D Fabrications.) Gear ratios are: (1st) 2.95, (2nd) 0.94, (3rd) 1.34, (4th) 1.00, (5th) 0.63. Chevy transmission mount. TransAdapt bellhousing (from D&D Fabrications.) Clutch is a Weber 10.4", with a Weber HTOB. Flywheel is a 22# steel Weber. Master cylinder has a bore of 3/4".
Rear Axle: Ford 8" 3.55:1 (from a Granada) rebuilt and modified to fit by Ted Lathrop, of Fast Cars, Inc. with an Auburn cone-type limited slip differential.
Front Suspension: Stock MGB except lowered by use of shorter springs. Shock valves have been replaced with heavy duty valves, and a Ron Hopkins sway bar added to improve the handling. Steering rack is from a later (1977) model (which has a "slower" ratio and thus more turns lock-to-lock).
Rear Suspension: Lever type shocks have been replaced with KYB tube shocks. Fiberglass springs were originally fitted, but they delaminated so original-type steel leaf-springs have been retrofitted. A Ron Hopkins sway bar has been added, along with a Panhard rod and unique traction bars to keep everything under control.
Brakes: 11.75" vented Wilwood and C&C hats in front, 10.75" solid drilled Wilwood discs in rear, both by Fast Cars, Inc. Brake master cylinder was replaced with a Mark II dual unit.
Wheels/Tires: Compomotive 16 x 6.5, 29 mm offset; 4.9" backspace, with Dunlop 9000 205/50ZR 16 tires. Note: fenders were trimmed to the welds for clearance, but flares weren't needed.
Interior: 1990 Miata seats with custom "Katskin" leather upholstery, custom door and rear bulkhead trim panels were made up by Billy Murdock's upholstery shop, Brevard, NC. They incorporate the MG logo on the doors, and additionally include "V8 Power" on the rear bulkhead. Carpeting was provided by Moss motors. Air conditioning is a Hot Rod Air unit, with fold-flat Acura eyeballs behind removable original console speaker grill. Kenwood stereo system.
Body: Visually, the body is stock, but modifications have been made to the floor crossmembers and to the bulkhead. The "frame" is strengthened by the addition of an extra transverse U-Channel bracing at rear bulkhead and A Post, and extra longitudinal U-Channel bracing forward of rear bulkhead. The firewall and the front valance are from a 1977 MGB. A full body restoration was done by Gary Nye, of Nye Performance, Brevard, NC. Gary is an artist with metal. He did a great blocking job - very straight! The paint color is XKE Series 3 British Racing Green. 3 coats of acrylic enamel were applied over multiple primer coats. Hood and trunk struts are from Ian Pender, although the lightweight aluminum hood only requires a 100# strut.
Electrical: Gauges are stock. Windshield wiper was replaced with a 2-speed Mark II unit. Wiring was replaced with a Painless Wiring system.
Completed: 5/1/2003.
Miles Driven: not enough! (as of the British V8 2006 meet).
Warnings: Glass springs delaminated going into 2nd. Ted's work with a 3.55:1 rear and posi, along with the tires and a stiff body makes for a good hook-up. Face beginning to hurt from constant grinning. Original 9amp cooling fan wasn't adequate.
Comments: Don't wait, just do it. I should have done this 20 years ago!
Things I would do different on the next conversion: install traction bars before the rear springs delaminated. Install a stronger shrouded fan to begin with. Seal windshield before the Tennessee monsoon hit (at British V8 2003)!
The inspiration for this car came from Pat Dempsey when he parked his car in the car corral at the 2000 Rolex 24 hours in Daytona. Amongst the Cobras and Ferraris was the perfect car: an MGB with American muscle. After talking with Pat, my little brain wheels started turning. The following Fall we went to the Cleveland V8 Meet and we were hooked. There was no turning back. Every car and owner there gave us ideas. We then studied the back issues of the Newsletter and found a solid(ish) car to develop. A friend called with a $150 parts car (What a deal, honey!) and we went into the shop.
Conversion of an early car would be a tough job without professional help on the firewall exchange. The guys taught me how to work on all parts that I couldn't permanently ruin, but I was continually in awe of folks who know what they are doing.
The car with an aluminum hood was a challenge, but the clean lines and steel dash of older cars was desired. And yes, I love those pull-handles. We recommend getting ideas from street rodders for wiring tricks and interior designs. The interior work on the seats, dash and panels is very rewarding, as we don't usually actually sit in the engine bay.
Lastly, I added a roll bar and bought more life insurance. All the folks we worked with were great. They all helped create ideas, rather than just selling time and materials.
Robert and Dreama Milks
Robert and Dreama Milks at BritishV8 2006, Townsend Tennessee
Buick 215 aluminum V8, note extended dipstick tube and tilting hoist mechanism
engine overview, including AC system
MGB hood struts (aka gas springs)
2010: BeCool aluminum radiator has replaced the earlier D&D unit.
2010 update: BeCool aluminum radiator has replaced the earlier D&D copper/brass unit.
2010 update: a smaller water pump pulley speeds coolant flow rate.
trick for purging air from cooling system
Jet Hot coated headers
RV8 style headers
evaporator and heater core
Moroso remote filler
sight glass for coolant level
Bodyshell Modifications
Drivers side footbox.
Passenger side footbox.
Motor mount (passenger side).
Steering.
Steering.
Motor mount (driver side).
Torque rod.
Torque rod.
Lateral torque rod.
Lateral torque rod.
Hidden conduit for wiring.
Floor reinforcements.
Spring perch reinforcement from above.
Spring perch reinforcement from below.
Transmission tunnel.
Completed firewall modifications.
Rear Axle and Suspension
traction bars by Gary Nye of Nye Performance
telescoping traction bars
valve spring trick
Ford 8 inch axle
MGB battery boxes converted for storage
2010:
custom MGB interior
sculpted MGB door panels
rear deck trim
2010: voltmeter
Exterior Details
grille
mirror
pullhandle mgb
MGB boot struts
Compomotive wheels
Did you enjoy this article? www.BritishV8.com is partially funded through support from readers like you!
Robert at home in his workshop.
