British V8 2007 Tech Session: Rear Axle Selection and Set-Up
as published in British V8 Newsletter, Volume XV Issue 2, September 2007presented by: Dan LaGrou of D&D Fabrications
coverage by: Curtis Jacobson
D&D Fabrications recommends General Motors 10-bolt axles for MGB engine swaps. Dan Lagrou explained this way: the stocks of competitive Ford axles are older. The end of production of the 9" Ford axle was 1975 or 76. The end of production for the 8" Ford axle was in the early 80's. The Ford 8" was used on some Mustang II's. (Dan didn't discuss the Ford 8.8 axle, which pretty much replaced both the 8" and 9" Ford axles and is still in production.)
The small GM 10-bolt axles have a ring gear 7 5/8" in diameter. Some 7 1/2" axles were made early on, but the pinion was smaller and other parts were non-standard, so Dan recommends that people just avoid these. Around 1989, the 7 5/8" axle changed from 26 to 28 splines on the axle shafts.
Fill up to the level of the drain plug with hypoid gear lube.
Even if they narrow their own housing, most people do send out for new axle shafts (from someone like Moser Engineering.) When you go to install the new axle shafts they should slide in and out EASILY. If they bind at all, the axle isn't straight. (Note: if the axles do bind, all is not lost. Bent axle housings aren't hard to straighten by a professional.)
Various limited-slip differentials have been used by GM in the 10-bolt rear axle. GM switched back and forth between Eaton, Auburn, and Zexel Torsen.
Option 1 (from the Versailles) is an iron caliper and a helix parking brake
Option 2 (from 92-99) is an aluminum caliper, and the parking brake is inside the rotor bell, which works better
Option 3 (from 99-on) is also an aluminum caliper, and the parking brake is inside the rotor bell, which works better
(Option 3 is shown in the photos.)
Dan also mentioned the 9-bolt "Australian" axles as an alternative for MGB V8 converters.
Dan described these as a heavier duty axle that's still in production. They shouldn't however
be confused with the 10-bolt. The 9-bolts have been used in 350 "Tuned-Port" Camaros, (and
some other F-bodies between 1985 and 90) and they are thus fairly common at swap meets.
Expect to pay about $300 for one.
The Australian axles actually have a long history and have been used in many, many cars. They're also known as "Borg-Warner 9-bolt" axles or "M78" axles. These axles entered production in the late 1960's by BTR Engineering Ltd., who was later bought out by Borg-Warner. Borg-Warner has subsequently been bought out by Dana. Besides Camaros, these axles have been used in Australian market Ford Falcons, Plymouth Valiants, Holden (GM) Commodores, Toyota Corrolas, Nissan Skylines, Morgan Plus 8's, and some models of Datsuns. In the UK these axles have been used in Vauxhalls and Jenson-Healeys.
Need a driveshaft? D&D also makes and sells driveshafts specifically for MGB engine conversions. They charge $225. You need to specify the length of the driveshaft. When you measure the driveshaft, keep in mind that you need to allow one inch of "pull out" at the transmission.
Photos by Curtis Jacobson for the British V8 Newsletter. All rights reserved.
